  • Replies 76
I had ask a compliance shop since you changed a engine before fitting a compliance plate your car in un-compliable in QLD may be its different in your state and I would like to offer you $8000 for it as a track car i got another spare engine let me know $$ ready
pm has been sent. like i say to anyone who pms me or replys to the thread! THERES A NUMBER THERE FOR A REASON IF YOUR GENUINELY INTRESTED CALL IT! simple as that cheers.
Very interested at this price. Will you guarantee it can be complied? What import paperwork do you have? Have you checked that the ring landings have not lunched the turbo's on the way out? Who did the import?
Thanks
Forgot to mention, that you mentioned..... " the car still can complied with a diffrent engine theres just a diffrent way of going about it!". Can you explain what this process is? Sorry I can't ring you to discuss, I am actually on a boat in the middle of the ocean and the Sat Phone is a bit pricey.
Thanks :geek:
mate theres too much to explain but the car can be registerd and complied either way if your that intrested you will call and find out about it. no offence but i wont take no one serious untill i get a genuine caller or someone comes to inspect the car coz ive had plenty of people stooge me around as you can see. cheers
Hi Loky,
I buy lots of things sight unseen while on the boat working, my unit, just about everything in it AND my last car, but I am having some reservations about your unwillingness to answer any of my questions on the forum. This usually indicates somethings wrong.....As I can't phone you and my only avenue to ask you questions is on this forum, I will give you another go at answering my questions if your really want to sell the car and have nothing to hide.
Thanks again
:bunny:
Hi there - obviously you imported this under SEVS, in which case a specific RAWS has applied for the compliance plates on your behalf.
Can you advise who this is, so that interested customers can confirm with this compliance workshop that they WILL guarantee that the car can be complied? For instance, what chance the buyer will spend $5K on an engine rebuild (in and out for an RB26DETT is usually $1K by itself - unless you can also quote the workshop who'll do it for $2K).
No offense mate - but if it is likely to cost $2K to comply and $2K to fix the engine and you reckon it's worth $20K, then costs aside you'd net $16K ($20-2-2). However, as you'll probably only get about $9K as it is (I'd be budgeting $3K with RISK for the compliance, and $5K for the engine....nobody cares about it being R33 Series 3), plus $1K for on roads - meaning $9K in costs, and seriously - even then you'd only sell it for $17K anyway in this market. So if you can get $9K from some one, take it, because it will cost you $9K extra anyway.
I will make a genuine cash offer of $7000 conditional upon certain details, such as name of compliance agent, whether he'll honour your $500 deposit (as this is a contract he has with you, and not the buyer) - I'm not even sure you can dispose of the car without compliance - check an import approval, I think it says this. If I can't get compliance (hence it's only a track car), my offer is for $4K only.
I'll also offer you a swap for an FC3 RX7 turbo coupe if you're interested.
Cheers,
Jessie
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
