King spring low.
front 3.2kg/mm
rear 2.9kg/mm
Why are u running r33 springs in the rear when s13 coilovers fit right in with very little trubble.
s13 coilovers also fit in the front with some moderfercation (i.e diffrent parts)
also allows you to run r33 gts-t front brakes.
http://wiki.r31skylineclub.com/index.php?t...sion_Conversion
Yeah I had the same thought you did and brought some s13 hubs and arms then worked out it was to much to spend for very litle gain.
The r33 struts in the back is because a mate had 33 struts sitting there out of a half cut and just decided to give it a go and it worked well and when he stripped the car I grabed the whole diff, struts and arms it off him for my car for $150 because i wanted the 3.7 ratio and another set of arms to put my new bushes in
and as for the front end it has white line springs, kyb shocks r34 gtt brakes so I cant see the point in spending all the money to go to s13 front end. ill profer to spend that money on swaybars
  • 1 month later...
Ah your front end is very simier to my old front end but i used r33 gtst brakes and had k-mac adj camber caster top hats. yep get some bigger sway bars, strut brace, cusco brake master cyl brace ($110 from powerplayimports under r31 house) and nolerthane bushes and it will handle realy good
can you shed some light on yuor rear end i.e pics im a bit confused
All the bushes are nolithain and yeah Im allready looking at swaybars, strut brace and the cylinder brace.
How hard were the camber tops to install?
As for the rear end well its a long story but a mate got bored and did it on his budget track build (I.e. under 4k build of pintara rb20det, ebay t3t4 turbo kit, r32 front brakes, weldy you get the idea) and it ended up in my car when the bushes went in just to see how it would go in my car
Im a bit hesedent to post photos due to looking a bit dodgy but the set up has done about 8k worth of driving, 4 track days and 3 drag meets with no signs of problems. tho there might be one in my build thread \/
Edited by lawler
Can you send the pics to deano864@hotmail.com then.
as for the camber tops its pretty easy.
remove the front spring assymenbly fromt he car.
then atach sping clamps (they compress th springs)
compress the springs so the tension is take off the top hat.
then undo the nut in the center of the top hat and remove top hat.
install k-mac adj top hats re do nut release thenions on springs and reinstall
get wheel aliment
that easy
then to adj jack car up losen the 3 nusts and move the spring around.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
