only an r33 gtr wheel from 96 onwards will fit onto a series 2
y would u want to anyway? they are exactly the same design
Hey mate your wrong.
OP. Mate if I get you right, you have a R33 Series 2 wheel and you want to buy a GTR wheel and put it on?
Now is the wheel in your S2 GTST the one with the raised centre?
If they are the same shaped/style wheel, they will swap over without a hitch.
If they are not, theres a little bit more involved, but still doable.. Clarify yourself more and I'll tell you how.
um thats wot i was saying,
a steering wheel from say a 95 r33 will not fit onto a r33 from 96 onwards coz of different airbag clips and u r unable to get the airbag to work. (yes they will physically fit on) but airbag wont work.
i know as i put a r34 gtr wheel onto my 95 r33 and thats wot the problem is. r34 and r33 wheels from 96 onwards have the same airbag sensors and clips.
as to why he wants 2 change wheels, there is no point unless yours is scratched and ripped otherwise they look exactly the same
  • 3 weeks later...
No sorry mate you are incorrect, I have taken my 1995 R33 GTR and fitted a 1997 GTR S3 wheel to it, It can be done? My airbag is also connected and working.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
