I got an S-AFC soon after getting my mildly modded car (T04 turbo, exhaust, boost controller, small FMIC) and it gave me a uniform extra 15rwkw across the board.
Then after a few more mods, which were a bigger FMIC, new front facing plenum, bigger fuel pump, upgraded wastegate actuator to handle more boost, and running higher boost, the car got 2 massive dips in the powerband even after re-tuning the S-AFC. I had more power up top, but it felt very flat after 5000rpm or so.
At this stage I upgraded to a PowerFC and it's fixed it. And I haven't even tuned it yet. I don't think it was a case of the ECU and S-AFC not handling the power, I just think the airflow was so radically different from stock that caused it to have a bit of a sad. There are other guys running over 215rwkw with S-AFC and no problems. Part of it is luck.
I say you should get a second hand S-AFC, and when the car starts not coping, sell it and get a PowerFC.
I know PowerFC is defectable in SA but is the SAFC?
are you serious?
how can the defect u for a PFC
coppers rip off ur kick panel and go "show me ur ECU"?????
its gettin beyond a joke this defect bullsh*t
Oh another question, with cam gears do you need a aftermarket ecu to run after market cam gears?
You don't need an aftermarket ECU to run adjustable cam gears but it may help. I installed mine and I found that the best setting was on 0 degrees (ie same as factory). This may change after tuning though.
You can't easily tune them yourself at home, best to do on the dyno where you can monitor the air fuel ratio so you don't run it too lean. If you know how to use a dyno properly it should take around an hour, otherwise give it to the workshop and they'll charge you around $200-300 for the same thing.
2GU UP
I am dead serious, the cops don't pull off the kick panel.
But the Registration office that does the inspections for defects will pull your car apart looking for stuff like this.
I have even heard of inspectors undoing the casing to look at the circuitry on the ECU to check that it is standard. You would have to be desperately unlucky I would imagine.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
