Selling my Alpine PDX amplifiers. I have PDX 4.150 4 channel and PDX1.1000 mono amplifier.
PDX4.150, is has seen very little use and car hadnt left the garage and quite easily passes as new condition. comes complete with manual, mounting hardware, birth cirtificate etc. will not dissapoint absolutly perfect. $550
PDX1.1000, is new in the box. $650
pm or
sms/ph: 0450 606469
https://www.sau.com.au/forums/topic/298548-for-sale-alpine-pdx-amplifiers/
just have to comment, thats very cheap. maybe wait a month, and re post at maybe 300 below retail, rather than half of it... people might think that they're stolen/broken/something wrong with them... but great amplifiers at that price...
Want these gone before Xmas or they stay with me. I now have more pics available of the actual items for genuine buyers.
Genuine sale guys, any inspections welcome. The entry level Alpine amplifiers sell for more than this at JBhifi. These amplifiers are currently Alpines premiem range. Will not dissapoint.
Truely an imressive amplifier combination which will get you the very best from your sound system. Big savings here and will do a deal on both amps if purchased together.
dam there cheap i wish i didn't buy retail.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
