  • Replies 46
there are 4 runs each differnt colour of pattern of line. The upward hill lines are the max power. The bottomw jagged lines are a/f ratios.
an ideal afr on a turbo car is 12:1
meaning 12 paers air to one part fuel.
on a na car its about 14.8:1 me thinks
Question: Why the hell on your dyno graph do u run real lean when it gets to red line around 6500-7000rpm???? Dangerous?
Enrico: Not sure why the graph runs lean at the end... The car was only run to 6500-6700 before the dyno operator backed off... Looking at the graph here, the lean AFR's aren't under power, so I assumed this was just the AFR's going into decelleration mode?
Even so, nothing goes over 12.5 which isn't "too" bad.
To be honest, I don't think the dyno operator really knew what he was doing. I certainly wont be going back to that establishment...
As for 2nd gear? Mines auto... Trying to keep the auto in 3rd or 4th when flooring it from low revs is impossible. Kickdown takes over and your in 2nd gear again :D
Noones ever successfully explained to me why dyno runs need to be done in a certain gear anyway... If it's to do with the ratios, how can we compare between say, a bombadore and an r33 on the dyno... Even if they both run in 4th (1:1), the diff ratios are different anyway...
Thoughts?
Looks like he did a 2nd gear run too. the fuel leaning out is taking foot off pedal.
strutto, if that was fully stock (which it appears) that dyno shows a nice healthy engine - ripe for the modding:)
hippy, it appears to me that street tuning is something that takes a bit of experience. Not too many tuners around these days that do it anymore, infact I dare you to tell me the name of one in Adelaide:) The road side of things is good for off boost and driveability, but you need to get the car on a dyno for a final trim and to make sure everything is ok.
Also, just do be careful you dont go crazy and pull too much fuel, just because you dont have a huge amount of mods, doenst mean you cant smash ring lands if you pull too much fuel.
Well the reason people say to do the run in 1:1 gear is that power is a function of torque and rpm.
Imangine if you use a lower gear, the mechanical advantage will be higher, therefore the torque will be higher, giving a higher power figure.
That is until you get to peak power, which will read the same, as the wheel speed is alot slower for the same rpm (as in a higher gear) but as the torque is higher due to mechanical advantage, the difference is cancelled out.
My understanding anyways, and I do have the 3rd gear and 4th gear dynos with the same power to prove the theory:)
Hmm, well if you have got a 3" from front pipe back, you 'should' be getting more than 5-6psi. Stock boost is 5psi to 5000rpm then 7 psi to redline, you should have a couple of extra pounds with cat back..
dynos not bad though, I didnt read the previous posts and didnt realise it was an auto till after I posted:)
This was done on 5-6psi...  (No factory bleed, DIY bleed closed).
Yea, I have disabled the factory bleed and use my own incabin bleed. This was closed during the dyno runs. Factory wastegate opens at 5psi I believe. The extra 1psi or so up high is due to the less restrictive exhaust I reckon...
interestingly enough, my safc was used to richen the mixtures up top....
It did 5 runs on the dyno in 4th gear and by richening the mixtures (+9%)from about 5k onward (75%throttle) I was able to gain a healthy 17rwkw and totally eliminate pinging. The car has a much fatter power curve and feels 100% better on the road. Plus I have the peace of mind that it isn't pinging and is safe to run at 12psi.. I'd go dyno tuning over road tuning unless you really know what you're doing.
hippy u r gonna fark your engine up man.
it only takes about 30mins for someone that knows what they are doing to tun your car on the dyno!!
also fyi i could get my gfriends old 1.3 litre mazda 323 to wheel spin in 1st gear, so spinning the 33 in first is no biggie! :P
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
