Central Coast & Newcastle People - Meetup To Go To Show N Shine
OMG.. andrews alive!!!!!!!!!! Will wait for a text from u.. that or ill be banging on the front gate at 6am!! haha
:P haha hey man. banging on the gate..... or throwing rocks at our bedroom window ...... its all good!! lol i'll sort it out man.
So WTF is going on? Im confused.
Is the meeting point at the F3 servo or opposite the RTA truck inspection station or both?
Can someone post the FINAL details please. Including meet time and departure times from whatever meet point.
i think there should have 2 meeting points for the coast because comming from the south end of the coast is a bit much to come up to the twin servos
Hence why I was thinking about only having 1 meet point which will be at the foot of Mooney hill just before the hawksbury bridge. :)
Keeps the northerners and southerners happy. :D
Hence why I was thinking about only having 1 meet point which will be at the foot of Mooney hill just before the hawksbury bridge. :down:
Keeps the northerners and southerners happy. :)
You mean where the exit to the old pac is heading towards sydney but on the actual old pac rd cause no much room in off ramp bit?
drew, on the off ramp there is plenty of room ( depending on trucks..) if not yes go around the corner and park on the old pac. will just have to turn around
thats what i was sayin last night. old pac side before the freeway entry. the freeway side will be packed with cars that oldies own, comming home from theyre weekend away, bladders and bowels failing on them why they que and clog up the public toilet haha :blink: 7:00 - 7:15 meet leave around 7:30 gives us a nice hour and a half to get us all there on time. whatchoo think fella's?
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
