R34gtt 1998 motor.
Forged Aries pistons 30tho
main and conrod king bearings
crank ground balanced
pistons rods balanced
Gates performance timing belt
crank fitted with r33 harmonica ballancer as other was damaged
block was checked and acid bathed
new valve stem seals in head, cleaned and re surfaced.
hks 2mm stopper type headgasket but head removed from motor for inspection
Cams not included.
Motor has been run for aprox 100km. Not yet run in
Built by superbalance. over $3000 spent on rebuild
open to reasonable offers $1000 and above only!
Garrett gt3582 t3 turbo New never used. $ open to reasonable offers
Turbo smart Ultragate38 2 bolt External waste gate. Never used .New
Engine does not include auto trans wiring harness and computer.
Picks upon request
Also have 33gtr complete plenum with homemade adapter plates and aftermarket injecters to fit up to neo or rb25det engine. $ open to reasonable offers
Email [email protected]
Ph 0431423291
https://www.sau.com.au/forums/topic/299367-fs-r34gtt-forged-engine-and-parts/
R34gtt 1998 motor.
Cams not included.
Picks upon request
Ph 0431423291
located Cobram Vic 3644
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
