So hi,
Car is in the shop having all the engine mods done, and I get it back on Thursday.
Meanwhile I have some stuff to go on, and id like to not have to stop half way thru cos I cant work something out.
Tail lights - I've had a quick squiz and it seems getting the inside hatch panel out might be tricky, anyone know where all the bolts are?
Roof Racks - How do I get them off? I want to respray them
Outside door trims - Want to paint these too, whats the best way to get them off?
Weather shields - Same again, how to get them off?
On a side note, Ill be mucking around making some eyelids too, I'll be making a few styles to see what I like, any left over will likely be thrown up on here. What looks good?
Stag is a S1.
Thanks!
https://www.sau.com.au/forums/topic/299418-detailingcosmetic-mods-halp/
Rear tails for the outer ones theirs two nuts you can see when the tail gate is open, Undo these then the lights pull out with alot of force (theirs these plastic locating lugs holding them in) Then u have to remove half of the inside hatch panel. Its not that hard mate just look at it and you will work it out.
Weather shields are on with clips and an adhesive.
Weatherstrips - best to remove side glass first - use pick or small screwdriver to remove plastics clips from inside door.
Outside Door moulds - glued on and locators(no clips) - pull hard
Roof racks - bolted and doudle sided tape - remove headlining to access bolts - Be careful!! (cast alloy)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
