Guys,
Just wondering if someone has a pair of these hanging around to measure up?
Im in need of a mounting bush to ball joint length.
I dont have any on hand, and local wreckers have none in their yards :D
Also some pics of how the castor/ radius rod mounts to them would be awesome,
from memory r30 is longer than r31 but didnt measure years ago when I looked at them both.
Cheers, :)
https://www.sau.com.au/forums/topic/299482-r30-lower-control-arm-lengths/
Alright guys im running a new group buy for r31 rose jointed adjustable caster rods.
These quality arms are built by Cazman industries in south australia.
http://www.cazmanindustries.com
Cazman industries is a small company in south australia which was started to fill a void in the market. They are currently making adjustable arms and products for many of the drift cars in south australia including the CTS car. They aim to sell the highest quality products with minimal markup to help the drifting community.
I have been speaking Dave from cazman industries over the last few weeks and he has realised there is a massive hole in the market for r31 skyline adjustable aftermaket parts and has agreed to run some group buys to help the members of this club out.
These arms are rebuild-able item with all spare parts being available to you as a spares service.
They have been built to both strong and of the best quality that your money can buy.
We offer a 6-month unlimited kilometer warranty on the rod ends
We offer a 1-year warranty on all turnbuckles
We offer a 2-year warranty on all fasteners.
Quick specs
Common US Made 3/4" Chromolly Rod End
Chromolly Caster Rod Zinc coated for protection
10.9 zink coated Cap Bolts into the control arm
Stainless misalignment spacers for less Rust and a stronger part
Zinc Coated Steel Turnbuckle
The Rod ends are a common 3/4" size and can be replaced with any 3/4" rod end, you can buy these from CBC, VPW etc. The other alternative is to bulk buy out of the USA like we do. This ensure that you get a US built quality rod end for a decent price.
We use a US made rod end, its nylon impregnated, not teflon, as teflon breaks into chunks (pounds out) The main advantage of our gear is the rod ends are a common size, most being 5/8 or 3/4, so you can literally
shop anywhere in your state and buy replacements.
The Rod ends are 4130 Chromolly with a stainless bearing. These rod end iteself 1 piece billet item, not
a pressed in COM bearing like our Chinese Competitors. By doing this the COM bearing loses its tight teflon liner tolerances and has increased stiction and wear.
We use dust boots on all our 5/8 products too. The 3/4 caster rods we cant logistically use, or it would add $25 to them. If there is enough interest we would order the dust boots in from the UK.
The Caster Rod is a chromolly item to ensure no breakages occur.
10.9 Cap bolts are used to secure it to the lower control arm. These are stronger than 8.8 and are easily replaced. You will require a 10mm Allen key to install your new arms.
The nut features a nyloc thread to ensure they don't come undone on you.
The misalignment spacers are made from Stainless also, so that there is no chance of braking, or rust transferring onto the rod end. This ensures your rod end stays in working order for longer periods.
The turn Buckle is a Zinc coated steel item with 3/4" Threads. these are made in steel as opposed to chromolly as these are designed to bend rather than break in the unfortunate event of a collision. The turnbuckle must always be a fraction weaker than the caster rod. The cross section of the hex turn buckle is still great enough to offer superior strength.
The above two pictures are showing the cazman industries s13 arms just to give an example of what your r31 arms will look like.
The r31 arms have 5 more components that the s13 arms dont have including the U bracket and the stainless spacers to go into the chassis etc etc.
PRICES
Introductry price is $320.00
10 or more people is $300.00
postage is $20 to anywhere in australia.
If there is enough of a market we hope these arms may become a stocked item readily avalable for r31 enthusiests to buy, this also may include various other aftermarket products that we are looking at building for aus and import r31's
A minimum deposit of $30 is required. Once we have 10 people on the list the order for all the parts will be sent off and it will be approximatley 3-4 weeks for the arms to be completed.
The list of people who are interested is here once it fills up to 10 people i can put my account details up, this thread will be moved into the active group buys section and i will start taking deposits.
Interested List
1.Ad's DEPOSIT PAID
2.Kitto DEPOSIT PAID
3.Boostin 31 DEPOSIT PAID
4.Bridgy DEPOSIT PAID
5.Ignition Street Dreamz 31 DEPOSIT PAID
6.TheOriginalArachdog DEPOSIT PAID
7.Mainyard DEPOSIT PAID
8.VL Eater DEPOSIT PAID
9.RobM-Z DEPOSIT PAID
10.Drift Gts DEPOSIT PAID
11.Floody DEPOSIT PAID
12.XR-PILOT DEPOSIT PAID
13.SIR_031 DEPOSIT PAID
14.project r31 DEPOSIT PAID
15.G DEPOSIT PAID
BANK DETAILS
Commonwealth Bank of Australia
Acc Name: Edward James Painter
Acc Number:10189405
BSB: 065148
Alright guys i have reduced the first group buy number to 15
You can start making your minimum $30 deposits as of now.
Please leave your username as a reference so i can keep track your money,
And also send me an sms on 0430327597 once your deposit has been paid
with your name and your username and the time and date deposit was made
The $30 deposit will be deducted from the final amount payable
if you would like to combine shipping to save costs please let
me know when you make full payment.
could of just started a new topic?
Im asking more of fitting "datsun style" steering and susp components in my s13..
Easier and cheaper to get your stock castor rods milled down and the thread extended for more castor, shorten the crush tube while your there, $30 castor upgrade :down:
Edited by works 510
excellent!
Ever run r30 lca's with s13 castor rods? thats what im looking to do.
I hoping the swaybar link hole and castor ro mounts are in the same position, if not, its re-drilling time
Dont know if it helps but I am running complete S13 front end (cross member, arms, knuckles) and am still running standard R30 sway bar and shortened standard caster rods (mounts point have not been touched) it all lines up sweet
Edited by DR JOSH
Indeed it does,cheers DRJOSH, if the stock r30 swaybar is used, means I dont have to redrill the lca's for s13 swaybar with r30 lca's.
Im actually doing the reverse, s13 running hr31 struts etc, why?, coz I like to modify and have all the parts here.
Easier to just buy some s13 coilovers, but that costs money :)
bit of trak, but does that mean u runnin a s13 rack 2 ?
yup, S13 rack, Bluebird steering column , Z31 linkages, custom engine mounts, a bit of stuffing around but it's all pretty straight forward. Would be a lot easier to do in a bluebird since they all ready have a rack.
mmm, interesting, ne bump steer ?
thats from the boganspek R31 forum...
I guess everyone that buys this adjustable caster bar realises that they will be deemed a SPORTS SEDAN in any club or better competition with rose joints in the suspension?
Cheers, D
Easier and cheaper to get your stock castor rods milled down and the thread extended for more castor, shorten the crush tube while your there, $30 castor upgrade :(
Mmmmmmmmmmmmmmm cheaper and a bit stupid for my money. Lessen the od and you loose it's strength because ANY heat will be detrimental to it's tensile load capabilities. Might only be $30 for the machining, but how much for the new heat treatment to return it to something resembling original????
Wouldn't it be easier & better in the long term to buy the SWR 5/8 (16mm) alternative for $195 set including new poly bushes and crush tubes.
Cheers, D
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
