Beat ya to it by 1 post so SHOT GUN the front guard liners (only need the drihers side) hahaha u can have the passengers side
Edited by SiR_RB
  • Replies 40
Hi after the complete front inner guard liners and fastners.
Also the Aircond Control in dash.
Can pickup Friday Evening.
PM me price and contact and will get back to you
sir rb beat you by one post :rofl:
but i dont' have any on the left side unfortually...
as for the aircon control dash.. pm me a price and we'll go from there
Dean
pm sent
pm sent re the coilovers
Nick
pm sent
the car had tein c spanners so I'm guessing tein..
But unsure.. I'll find out for you..
Also unsure if the coil overs will fit a r34.. I'm sure you can find some info on here tho
You have pm RE coilovers :P
