Well today turned out to be a black saturday for me today.
been to pick up some xmas pressies as we do and I took off from the lights sedatley got to 2nd i think and (no bang) rattle rattle loose oil pressure?
I was travelling about 30-40kmh and only about 100m or so from the lights and at first i thought i ran over a can on the road or something.
I am no mechanic but if seems bad.... Sheez I only had my timming belt, pullys, water pump done 3 or so weeks ago..
Anyway I have confirmed that my belt is still attached as I can see thru the oil cap when the car is in gear and see the lobes move when i rock the car back & forth. So where does this leave me broken piston conrod valves etc $$$$?
Car has done only 104k.
I was saving up to get the hiflow turbo serviced and put new seals in as it was starting to let oil thru under excelaration
So where do i go from here? and who car I take it too in the SE suburbs (Cranny, Dandenong areas)
I eventually had it towed back home as I was only 2km from base. was the longest drive home i had . Like a funeral march
Next doo neighbour (Nic the wog) says great now put all the big gear in as he starts up his v8 monaro only 10k. Unfortunately I am not that loaded so I need some advise how & where to start with this as is a daily driver not a race car had I think around 196rwkw
Need another drink!!!
>_<
Dazza
https://www.sau.com.au/forums/topic/299901-bang-rattle-rattle-rattle-oh-no/
ok so you said the timing belt, pulleys and pump were changed 3 weeks ago
ok so first thing is to check the state of those, do a visual inspection
can you see any damage on the belts, does you see any bits of metal shavings lying around?
what lights come on ? did you say oil pressure light? does the guage also show low oil pressure?
does it idle at all or even start? when it went bang (or no bang as you said) any smoke ? what colour?
and after all that speak to the place that did the belts etc and advise them something has failed
it could be their fault or it could be non related and a big conicedence, your best bet is to discuss with them
I havnt started to pull the cam belt cover off just yet...(just moping around in self pity...trying not to think about yet) I cant recall any lights coming on only that i totaly lost oil pressure. I turned it off straight away but its like when you put the key in your igition and all the light light up. there was no smoke either that i could visually see.
That car wont start now either...tick tick is all i get
Slightly pissed dazza
Edited by itshimdazza
Hey mate you should talk to Ben call him on 0433270360 he built my car JETLNR and WYTJET and TOT747 which mate 475kw on pump at RE Customs dyno day last night which won the comp. He will look after you in price, tell him Jeremy with JETLNR told you to ring him and he knows skylines back to front man. Try him out I guarantee he won't dissapoint. He is also the best tuner and all of our cars have been going for ages and we havent broken a thing.
if the car wont start at all or even try and crank over id say the timing belt is toast
it may have failed then smashed all the valves etc
pull the cam belt cover off and inspect it visually
if (and only if) the belt has snapped id say its likely the workshop who did it may have made an error
we have seen it a few times in the past, due to error a part of the process is missed or skipped etc
the end result is the car runs with a new belt but it snaps shortly after
when the belt snaps as the engine is an interferance engine, it smashes all the valves etc (engine is toast)
talk to ben and he will help you out with all your issues mate.
Jetlnr,
I gave ben a call and will organise for him to have a look possibly friday. seems a nice bloke and was telling about the big power builds (well over 300rwkw) that he's been accross. Hopefully he can give me the lowdown on my condition and maybe just maybe build it on the cheapish
Thats for his headup though. will let you know how it goes post friday.
Dazza
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
