Ok people , I have booked another one.
Morning session 8.30am-12.30 and limited again to minimum of 12 people at $100ea with the same format and training as the first two. I will be in the car with you giving encouragement, advice, help , abuse.... as usual. Hehehe
Trick with this one is I will be taking the details and names , NOT John Clark.
Cash , cheques , money orders , credit cards will be taken and there is NO , absolutely NO on the day paying.
We have been shafted 4 times by people not turning up so no pay/no play.
First 12 in get it and contact me on the details below or
0418 927 415.
Don't forget you will need to have done the training prior to being eligible for the drift demo series next year.
Ohh and one more thing , if you have already done a session with me , you are not eligible to enter again ( yet).
Sorry Mike , Gav , bangers and all you other drift nutters :D
__________________
Cheers
Ken
Hyperdrive Motorsport
9209 3100
1/28 Vale St Malaga
https://www.sau.com.au/forums/topic/29999-drift-training-310104-am-in-wa/
C'mon ya bunch of pansies.
Everybody talks about how they want to/are great drifters and how they do wondorous things in Canning Vale/Malaga/wherever but when it comes to the opportunity to strut your stuff , the silence becomes deafening.
Have 5 paid up entries and 3 more confirmed but not ONE from SAU. :thumbdwn:
Cheers
Ken
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
