Silver 1996 R33 Nissan Skyline Gts-t S2
Manual
Factory Option Side Skirts and Nismo Front Lip
120,000 Klm
Has had its 100,000k service and has been serviced every 5,000K’s since imported.
This has been very well looked after!
Has been Dyno tuned @ 244 rwkw’s
Mods are:
HKS GT-RS Turbo
Nismo 550cc Injectors
Apexi PowerFC & Commander (Hand-Controller)
Apexi Electronic Boost Controller (Connects to PowerFC)
3” Bell Mouth Front/Dump Pipe
Kakimoto Regu 06&R Cat Back Exhaust
Hybrid FMIC
Nismo Fuel Pump
Jim Berry Race Clutch (Rated @ 450 HP, feels like standard)
Splitfire Coil Packs
Z32 AFM
Apexi Pod Filter
Cold Air Box (not fitted)
HICAS Lockbar (not fitted)
17” Volk Challenge Wheels (8” Fronts, 9” Rears, Currently has Hankook tyres)
Full alarm, immobiliser and central locking
Kenwood double DIN head unit
Kenwood/Pioneer Front Splits (Original Kenwood 6” speakers died)
Kenwood Component rears
Custom moulded 12” Sub Box in boot (empty) which reduces boot space by only 2 inch’s
$22,500 ono
Pics to come
https://www.sau.com.au/forums/topic/300065-fs-96-r33-s2-gts-t/
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
