Hey guys have a few R33 parts i no longer require.
Unused set of Aus spec Tein Super Streets, havent been used, been sitting in my garage for about 5 months, comes with all the spanners and what not. Looking for $1300
Stock airbox and snorkel $60
R34 Snorkel only $20
All 3 rear seatbelts $25
Jack and kit $20
Skyline Door Garnishes $30
Rear Skyline Garnish $25
Rhs Guard in White, no badge still has the indicator but fairly scratched up would need a spray $75
In Brisbane.
https://www.sau.com.au/forums/topic/300079-few-r33-parts/
Replied to your pm's mate, sorry i couldnt help.
Also have a 5 Speed Manual Conversion kit, with everything 5 sp g/box, front tailshaft, flywheel and clutch, flywheel cover plate, clutch master cylinder, slave cylinder and lines, pedals. Looking for $1600
https://www.sau.com.au/forums/topic/300079-few-r33-parts/#findComment-4992214
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
