hey guys need to get rid of my daily as house almost ready an need to pay some bills.
dont really no much abt these thing only had it for about 3 months brought it from tassie
motor was rebuilt by last bloke only done about 2000kms since build just a standard rebuild
t28 turbo
heavy duty clutch
high/low boost switch 4psi/9psi
smoke faced boost gauge
jvc head unit
2 1/2 inch cat back
good fun to drive never had a problem with it
bad things
come's with no rego or roady
hole's cut in front door trims for speakers by last owner
little tears on back seats
want 2.5k or reasonable offer
https://www.sau.com.au/forums/topic/300159-cheap-daily-et-pulsar/
