Blitz Dttx Turbo Timer With Built In Boost Gauge Function
lol that would explain it
I assume you’re talking about the Daihatsu Cuore with the “Mira Gino” front end conversion if so it’s also turbo converted and makes ~100kw from the 1.0L 3cyl
Head is completely built. I tossed the entire Ferrea catalogue at it. Head has also had a lot of porting work done to it. When I see someone making 600+kw with a hydro s1 head in the rb25 turbo thread here, I like to presume it's not a head/rpm limitation. Although I agree, it would definetely help. 82mm bosch dbw, 4" core with 3" pipes. IAT's were ice cold on the dyno. It was 18c ambient and i'm shooting water/meth. -
I thought the K11 Micra front end conversion was pretty shmick
I'm confirming the "2 way" Nismos can be converted to 1.5's very easily as you already described. It's well detailed in the manual. I can scan mine if you need, I think I still have it laying around somewhere.
