Hey, I've been brousing this forum for a while now but it's time for a post now.
I've just bought a Do-Luck rear cross bar for my R33 but because it was 2nd hand there are no instructions and the guy I bought it off never fit it. So I was wondering if any of you guys have one fitted or know how to fit it.
Chris
https://www.sau.com.au/forums/topic/300689-do-luck-tunnelrear-cross-bar/
Yep, but when we installed a mates the flanges were welded on upside down :) haha...chinese shit, would NOT buy again :)
These do luck type braces are just bling for your interior. They make bugger all difference.
What you want is something that WILL work.
This;
Edited by r33cruiser
They fit R33 and R34 Mick. Maybe R32 not sure.
It stiffens up the chasis a bit I noticed. Eg you notice it when you jack the car up.
They just bolt straight to the seat belt bolts. Pretty easy to do. Just put the bar together first then once it's in the bolts for the seatbelts tighten the bar up.
Speedstar Racing don't list Skylines so can't use that bar. Looks like it would work pretty well though.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
