there nothing special . thay are a bit harder to fit than factory ones but do fit fine . they look taky shiny . not cool clear . if that makes any sense . and they stick out about 3 times further than standard ones .
are you sure you're talking about the same thing? :) they are the same as the standard ones, they don't stick out any further and they use the exact same mounting system :bunny:
Trawled through his website but he seems to have front indicators for evrything else R34, S13, S14 etc but not Stagea. He's just a couple of km down the road from me so i will go and see him tomorrow and ask him if he can get some in.
:) my apologies. Upon closer inspection it's just a giant orange globe, not orange plastic on the ends.
for my next question, anyone know where i can get a new set that aren't faded/dull?
Edited by Cheddar
  • 3 weeks later...
are you sure you're talking about the same thing? :P they are the same as the standard ones, they don't stick out any further and they use the exact same mounting system :bunny:
yeah thats what have . they are harder to mount beacuse they are shit hard plastic not nice plastic like factory ones . and by stick out i mean the lense has a lot more of a bluge in it . the factory lense is almost flat those ones are about 12 mm deep (outwards)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
