Guest RedLineGTR
From what i can remember you have to much around with piping etc to get it to fit but also its abit too big for it, its not worth it. YOu a 100% better getting a R34 GTT cooler they are thicker and bigger in all aspects u should be able to get them for about $150-$200AUD would be cheaper in New Zealand.
Ic, becasue the guys sell for me for $350, that's why i'm thinking of it. Becsaue i really don't know how much the Gtt intercooler it costs, is it that cheap for only around$250N.Z? By the way to fit an EVo 4 intercooler is it a bad idea?
Thanks mate
steven
