Hi Everyone,
Installed a Profec B-Spec-II. Was running a Turbotech mechanical boost controller at 10PSI. Was hoping to get the Profec to climb to and hold 10PSI similar to the Turbotech. Been changing the settings without success (many late night freeway runs).
I was wondering if someone could share their Profec settings, if they have a similar setup to me? Once I have a rough idea of what to do I can jig it a little, whilst keeping an eye on my boost and wideband gauges....
Basically I have:
- Full 3" exhaust.
- Stock R33 turbo.
- FMIC.
- PFC (untuned).
- Apexi Super suction kit (intake pipe and pod).
- 480cc injectors.
Thanks,
Peter
Edited by Peter
https://www.sau.com.au/forums/topic/301077-greedy-profec-b-spec-ii/
If your running an untuned Power FC I'd be taking it to a tuner to get it set up. I had mine installed and tuned + he set up the boost controller for me too (same one as you) for $500. Money well spent too.
Here's a link that might help you though mate.
http://www.skylinesaustralia.com/forums/Pr...l=profec+b+spec
where in perth are you? i can set it all up for you
Hi Mate,
I'm around the Cannington area. It would be great to meet up and let you set it up!
At the moment I'm just putting my door back together after it got dinged in a car park (just finishing up the painting etc.) and don't really want to drive it that much with all the police out etc. (it has no interior trim nor handle on the passenger door at present), but would definately like to meet once this has finished if that's cool with you?
Cheers,
Peter
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
