Would you do 900AUD for the Nismo coilovers..? Any chance you could post other pics of them and a little info on there condition and was also wondering if they come with the Nismo dampening tool..? For some reason, it won't let me open the full pic of the suspension..? Thanks and cheers... :)
Edited by levelride
555KKK, please ring Ben Stack from JMS (Japanese Motorsport) immediately.
Ben Stack
P 08 8363 5555
M 0402 317 513
He has tried repeatedly to call you but you won't return his calls.
It seems you only joined SAU to sell your whole cars and various parts as all of your posts are "For Sale" items.
Any more complaints about you not resolving issues with your buyers will see an immediate cease to your "For Sale" items.
I await his call in response to yours before proceeding further.
Some people can't answer their personal calls at work dh. The guy only sent me a text yesterday..
What is the reason for you bullying me here sled? Is ben stack your mate or something else? Dude.. it's been one day since he sent me a txt!
And just so you're aware of the full story,
1. he's had the block for over a month
2. he's had it worked on
AND
3. HE HAD IT CHECKED OUT BEFORE HE BOUGHT IT!
I've always been quite happy to take any of my parts to a third party before any money changes hands which has worked perfectly.
I've had plenty of people happy with the parts I've sold to them. I'm on here for the networking.. the information.. to upgrade parts on my car.. to get advice.. to give advice AND to sell the bits I don't need.
I'm not here to hold hands & sing Kumbaya.
Ben Stack
P 08 8363 5555
M 0402 317 513
As per your request via PM, no I will not delete my post.
He has been calling you for more than a day....if you liaise with your customers and resolve your issues, there won't be a need for me or any other Moderator to step in and mediate.
And if what you say is true regarding the block, then you have nothing to worry about.
just thought id put these left over items all on the one thread,
N1 block $1500
GTR Gearbox $800
Nismo 33 or 34 suspension $1000
Rb26 Cam covers Chrome $ 700
Rb26 Head complete $900
Apexi powerFC 32 or 33 GTR $750 $900
some bits are sold pm me if you want to know
I asked you to delete your post cause you jumped the gun & didn't have the full story. See above dude..
As for the phone calls, I cannot return a call to an unknown or private number- perhaps your gripe is with Telstra?
If he actually did ring at all, he should have left a voicemail & I've had no vm msgs.
And yes you're right, I don't have anything to worry about :P
Would you do 900AUD for the Nismo coilovers..? Any chance you could post other pics of them and a little info on there condition and was also wondering if they come with the Nismo dampening tool..? For some reason, it won't let me open the full pic of the suspension..? Thanks and cheers... :P
no dampening tool sorry bud
but pm me your email and ill send you some pics
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
