yeah mate thats what they came off, havent got pics but mayb able to sort something out. looking at 2700 for the turbo and manifold, open to any suggestions as well. cheers Matt
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-613375
  • 1 month later...
looking at only 1200 for the lot?? not sure on the wastegates. The manifold is back down at JMS you can give them a buzz to find out the size 0882606919
Also got the sub zero style plennum as well. If you have HPI issue 35 you can see it in there on my car. looking at 600 for that
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-658139
yeah, mate still got the engine and head? the engine has been re-built with standard stuff and the head is of atm. what are you after?
Actually wondering if you still have the old motor not the new one. However want one with the head. Dont need any plenums or turbos and stuff. Just something to stick in the shed and start pulling down myself for a rebuild.
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-658151
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
