Hey, tommorrow im finaly gunna get some ICE :P (new sound system) :D
And i was just wondering if is should amp my speakers, heres what im getting : all full alpine :ermm:
-Head Unit CDA-9886.
-Front splits SPR-17S TYPE-R 6.5" COMPONENT SPEAKERS
-Rear 6's SPR-17C TYPE R 6.5" COAXIAL SPEAKERS.
-12 INCH SUB, SWR-1222D TYPE-R 12" SUBWOOFER
-AMP FOR SUB, MRP-M1000 V-POWER MONO AMPLIFIER
And if i amp the speakers which i think i am it would be :
-MRP-F600 V-POWER 4/3/2 CH AMPLIFIER.
Is it a good idea to amp my speakers? like and extra 500 or so doesnt matter, and if im spending what i am it would be best to amp the speakers to get the most out of the system, would you agree?
also theres a new thing that plugs into the headunit (at the back) which ads like 65 rms to each speaker for 200$, dont relaly know much about it...
i have a JVC headunit, rockford fosgate 6.5 inch splits front and 6.5 inch coax rears. Doors fully lined with dynamat and all hooked up to a sony 4 channel amp. TO be honest i dont need a sub with that set up.
So my 2c is that YES YES get a amp for your speakers, as then they wont get drowned out by your sub and if youre paying for good speakers you may as well show their potential with an amp; but also GET DYNAMAT, makes R33 doors sound SO much better.
Thanks mate :D
yeah that what i though, might as well get the most out of it :P
dynamat.. now is that worth it?:ermm: ta
Definately need an amp, personally i would not bother about rear speakers though, i have focal splits front and rear and when i turn the rears off there is no difference.
If i was you i would go for a good 4 chan amp. run the fronts off 2 chans and bridge the other 2 for the sub.
why even bother putting type r splits without an amplifier? clearly states on the box that they're 110wrms..
alpine also do a package that comes with splits + 6x9's + amp for about 300 off retail.. i swap the 6x9's for customers all the time.
Maybe its just me but i think 6x9's are a poor mans sub that will never match a small 10" sub let alone a decent 12".
Step 1. Pull out rear speakers
Step 2. Dynamat, you don't need loads of it to make a huge difference
Step 3. Amp front splits
Rear speakers are almost always a waste of money, and stuff up the imaging of your front stage, unless you really enjoy sitting in the back of your car whilst driving, ditch the speakers and leave the holes empty. You will find you have heaps more bass in the cabin from the subbass in the boot having an unimpeded path to you.
cheers,
Jesse
Hey, system went in a few days ago, its really good :D amp'd and all, now only problem is sorting our the rattles. lol..
you know the "skyline" centre between the taillights, well bass shook two of the four nuts off, one each side.. but i couldnt be happier :)
A tiny bit of lock tight will hold them on, as for other rattles, you just have to go looking for them, some might be loose bolts or fittings some will just be parts rubbing or hitting, try some foam under some bits others try something like sika flex to attach the part properly.
its pretty much just my rear bar, but too unsure to put tension on it as it could stress and break?
Depends how much pressure you put on it, would take a lot to break it, find where it is rattling and just use a finger to push on it, if it stops you need to put some foam or something behind it.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
