  • Replies 117
MORE PARTS TO ADD TO THE LIST (Stuff has been added in posts since original post!)
- R32gts-t front 5-stud hubs and control arms etc - $200
- R32gts-t rb20det engine cross-member - $100 (suit s13 rb20 build etc)
- R33 gtr rear spoiler (damaged, requires fibreglass) -$70
- R33 rear pods (unknown make, one damaged) - $70 for both
  • 4 weeks later...
Are the R33 GTST door seals for both left and right? are they the ones on the chassis that the glass seals against?
Whats the condition of the HICAS ECU? Chasing a working one to replace my dieing one?
Thanks.
hey chasing, drivers side front gaurd front reo, radiotor support radiator, radiotor fan, ac radiotrr , ac condensor, front lights bonnet clutchfan , whateva u can hlp with price let us no. washer bottle over flow bottle
- R32gts-t rb20det metal cross over pipe (throttle body to I/C pipe) stock with no BOV fitting RARE perfect to run aftermakret bov and look stock - $40
- R32gts-t rb20det ignitor module - $40
ADDED TO PARTS LIST FOR SALE
r33 gts-t front rotors SOLD!
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
