  • Replies 117
Hey mate,
I'm looking to buy your dump pipe from the 32gtst.
How much are you asking for and how much would it be for the shipping to S.A post code 5120?
Pm me.
Parts to be added to the list
- r33 bonnet release cord - $20.00
- r33 bonnet relase catch, bonnet clip <- bit of metal down the front has horns attached x 2 - 20.00
- r33 dash vents <- near windscreen x 2 $5.00 each
- r33 engine bay fuse box and loom - $30.00
- r33 hazard and dimister button - $5.00
- r33 climate control unit $40.00
- Pet turbo timer and harness
- r33 clock - $10.00
- r33 charcol canister - $10.00
- r33 indicator stalk x 2 - $10.00 each
- r33 horns $10.00
- r33 fuse box lid $10.00
- r33 front bar indicator (left side) - $20.00
- r33 quarter pannel indicator (right side) - $10.00
- Greddy Oil Catch Can $30.00
- r33 Smart Entrance box
- r33 roof handles $2.00 each x 4
- r33 radiator supports pair $5.00
- r33 wiper motor- $30.00
- r32 gtr dash cluster - minus tacho - $10.00
- HKS adjustable CAM GEAR - $40.00
- r32 rb20 standard cam gear
- JJR manual anodized red manual boost controller - $30.00
- Mitsibishi FTO AFM - $20.00
- Procomp Mechanical Oil Tempreture Gauge -$30.00
- Pivot turbo timer $30.00
- r32/33 turbo heat shield $20.00
- 2 rb20 coilpacks $10 each
- r33 stereo brackets $15.00
- Single DIN pocket $10.00
- rb20det turbo fuel pump $50.00
- rb20det afm $30.00
- anodozied blue pod filter $5.00
- r33 rb25det coil pack cover x 2, $30.00 each
- r33 rb25det brake filler bottle $10.00
thanks guys!
feel free to look at the same add on boost: http://www.boostcruising.com/forums/index....entry1285120796 as you can edit it so all parts are under there respected headings and items that are sold are removed!! Still feel free to enquire through here or the contact details provided in both adds!
Got two questions mate
1. Do you have an r33 standard turbo that is in good nick?
2. Do you have r33 gtst passenger side window?
Cheers mate
Hey mate yes i have both pm sent! =)
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
