I went into super-cheap and their catalogue said QM1 paint is 'polar white'.
So I bought a can and painted my stealth lip with it but it looks too cream-like in colour. The white on my car is more brilliant like a little blue.
Anywhere you can buy jap spec QM1 in a can in Perth?
https://www.sau.com.au/forums/topic/301952-qm1-paint/
You didn't think shit in a spray can would match aged factory, 2 pak paint, did you? and you're not looking for "jap spec" or "JDM" paint - get a professional to match the color...they seem to be good at that kind of thing.
I was hoping for a close match allowing for some ageing, but this is defo a different colour. The colour/tone of my paint on the outside is not noticably different from inside the doors etc - where minimal UV light is recieved - anyway, so I don't think it is just because of 'ageing'.
I read somewhere that JDM spec QM1 is different than Oz spec QM1 which seems farking idiotic.
I was looking to avoid paying a pro to paint the thing. I'm a DIY kind of guy.
Edited by Tony de Wonderful
https://www.sau.com.au/forums/topic/301952-qm1-paint/#findComment-5010046
Paint codes are paint codes buddy, the same color code will vary depending on manufacturer and how old it is.
Its still best to pay a pro man, acrylic paint won't last long on your bumper. It'll naturally just start cracking and peeling off after a year or so...and it has basically no resistance to chips, scratches, etc.
https://www.sau.com.au/forums/topic/301952-qm1-paint/#findComment-5010108
I'll probably go down to Protec.
https://www.sau.com.au/forums/topic/301952-qm1-paint/#findComment-5010125
Do Protec sell to the public?
Looking at their website it looks like they're a distributor that will tell you to go to a shop that sells their products. They'll probably give you all the advise in the world though...which is - do something once, do it properly - use 2 pak :D
https://www.sau.com.au/forums/topic/301952-qm1-paint/#findComment-5010750
I used to use a colour matching company called colourtech. google it.
Located in perth and a mobile service. I use to have the super red pearl coloured 33 (1ANO) and was always a bitch to match but those guys (one of em was called Tony Stalker and DEFINATELY RECOMMENDED!) used to get it right every time, was good enough for the shows the car used to go in and would come up perfect!
https://www.sau.com.au/forums/topic/301952-qm1-paint/#findComment-5010778
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
