1989 R32 GTR Skyline
144,***km on chassis
Rebuilt R33 GTR motor - approx 6,000km
R33 GTR gearbox
Nismo Lemans turbos
ACL race series bearings & gaskets
N1 oil pump & new Nissan water pump
Tomei sump baffle kit
550cc denso injectors
Apexi PowerFC
Apexi AVC-R
Nismo copper mix clutch
Racing logic coilovers
Hicas lockbar
Front & rear strut braces
Zepter 18x10 +15 offset wheels with 265 35 profile federal 595s
Tidy interior, all factory gauges in working order
Torque split controller
Sony 7' LCD with multiple RCA inputs & 10 cd stacker in boot
Recently installed a new Bosch alternator & battery
Made 380 hp on a safe tune at PITS.
Car is registered and will be sold with safety certificate.
I bought the car when the motor had just been run in and tuned. It was tuned for 1.2bar however I have only used this a few times I drive around with the AVCR set to 1 bar.
My reasons for selling are primarily that I want a fourby/ute to tow my 180sx to the track so I don't have to keep it registered and also that the GTR is wasted on just driving 10km to/from work everyday.
$21,000 ono.
You can contact me via PM or call/txt my mobile 0418 708 307.
Alex
Edited by SMiTHBRo
https://www.sau.com.au/forums/topic/302339-89-r32-gtr-with-rebuilt-engine-21k/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
