booze bus marking (read Checkpoints in trapster) is a bit dodgy IMO, would make it way too easy for people to go out drinking then drive home with the app on missing the BB. Apart from that it is really good, I drove to Bendigo and back for work today and it picked up a radar about 3/4 of the way there. Was first cop car i've ever seen with no markings on one side (drivers) then on the other, full police markup!
  • Replies 90
Can't find the article now, but the Vicpol commisioner was saying that cops know all about Trapster, and that they would be able to put in false notifications or remove real notifications anonymously. Might be the reason why there are so many notifications? I know you need a mobile number but I am sure Vicpol easily have hundreds of dummy numbers used for investigation purposes.
If some one is going to add me on trapster can you let me know on here, had someone called leish that i added but they wouldnt reply to msg's asking who it was so i removed them, the same day intoxicated removed me, not that i give a f**k, the fact that this is a public forum and any one i add could quite easily pin point where i live (havnt nad my iphone long so im still playing with it all the time) and i have no idea who they are as i dont think you need to sign up or log in to view this thread is a cause for concern, so from now on if i dont recognise the name you use i wont add you, i have 2 waiting atm with the names of b1llyb0y and juicedcad_83, unless i find out who they are i wont approve them.
W0rp3D... ...That totally sounds fair... ...I've been in the same boat as you... ...When we first started giving out Buddy Requests I was putting in "SAU"... ...But those that didn't I didn't add...
Feel free to add be btw...
I really don't know who can view my location or what not.. I've set Discoverable to OFF.. can someone who has me on their buddy list click on my name and tell me what area it's showing me in?
Right now I can see locations of everyone on my list. Some may be work places, some may be homes.. but I don't know if any of you have set discoverable to off or not so I don't know if I'm viewing where you are without your consent.
Just want to know exactly what information this is sending out.. :D
If you can get trapster for the blackberry i would assume that all the features would be the same.
cant see a way to add friends or anything.. maybe im dud with technology ;)
on a brighter note absaloutly LOVE this app.
(george bush alerts FTW)
Edited by SKYL1N
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
    • I had the fuel rail out to check the injectors before getting the ECU reprogrammed. The guy said that the injectors were fine, but the regulator was cactus (leaking fuel out the vac port, randomly changing pressure. I decided to replace the FPR with an adjustable unit. I have purchased 2 now, and neither has an appropriate adapter to fit where the FPR mounts. I need advice on where I can get an adjustable FPR that will simply drop in on a RB25DET. TIA
