Item: 10 15 Row Oil Cooler w/ FULL Oil Filter Relocation Kit
Features:
- Keeps engine components at correct running temperature
- 10 15 row GReddy style oil cooler
- 290x205x50mm with a mega 600cm cooling area (front and sides)
- (-10AN) Male fittings size
- Oil cooler made of aluminium and coated with an anti-corrosive
- Full engine oil filter relocation kit
- Accepts all spin-on M20X1.5 thread size oil filters
- Sandwich plate includes ports for 2 extra gauges
- Comes with all nuts bolts and brackets
- 3 Earls type braided stainless steel flexi oil lines (125, 145 and 165cm)
- Practically a stand alone setup - easy installation!
Has been extensively used on all Nissan RB series engines
$345 including Delivery & Insurance SAU SPECIAL - FREE POSTAGE
Condition: Brand New
Contact: 0401599023 (anytime) OR [email protected]
CUSTOMER INSTALLS - Send us yours next!
  • 3 weeks later...
  • Replies 44
What do ppl think about this kit?
Looks alright, may be interested.
Can you get it with a thermostat?
Would also like to know this.
Hi mate,
Our kit does not come with a thermostat, but some customers do choose to purchase one separately.
- Brendan
  • 1 month later...
So is there a new batch in?
Hey mate,
Yes - we just got them in 3 days ago!
If you wanted to order one, we now have them in stock ready for delivery.
- Brendan
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
Hi mate, I have a genuine greddy oil cooler with lines that i bought a while back. Can I purchase the oil filter relocation kit seperately and if so will the braided hoses I have that go to and from my cooler fit the oil filter relocator?
I purchased a cheap relocator and sandwich plate that I put on my new built engine, the sandwich plate blew off the side of the block at 9000rpm and sprayed 10 litres of oil through jpc's dyno room. The thread on the sandwich plate was detroyed, so i want to be sure this wont happen agian.
Cheers
Mark
Cheers
Mark
Hi Mark,
Mate unfortunately at this point in time we do not sell the filter relocation kits separately...
But I must say our oil cooler kits have been used on some big HP set-ups and I have never heard of such damage, sorry to hear about it.
- Brendan
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
AND IT'S HERE!
Brand new batch just in - $345 delivered to your door :D
These are basically a complete stand alone set-up... can be suited to (almost) all engines
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
