hi everyone , finally up for sale is my project ae86 sprinter.
ive completed everything on this car , has recently had a complete respray in 2pak paint in the famous panda theme which was done in november 2009 .
this car is nice to drive , handles like its on rails and has pull to make you smile .
the body is in good condition , there is absolutly no rust on this car , all rust has been repaired in the process of respraying.
car has no accident damage and is straight .
car is a 1985 toyota sprinter adm
*4age smallport 100kw motor which has been rebuilt 7xxx kms ago with:
*genuine toyota headgasket
*genuine water pump
*all new seals & main rear seal has been replaced
*head studs (genuine) has been done
*cam seals replaced
*genuine waterpump
*timing belt changed in rebuild
*new larger 9 mm leads
*new dizzy and rotor .
its pretty much has all new gaskets through the whole motor
*the clutch is a fresh heavy duty replaced 7xxx ago
*lightened flywheel 4.1kg
*trd extractors with a custom 2.25 inch exhaust , pretty loud .
*t series diff with mini spool
*custom 2liter surge tank setup with bosche turbo external pump , and bosche internal turbo pump
*adjustable fuel pressure reg with gauge
*king springs on the rear , and ajps on the front.
the front guards are aftermarket flared fibreglass gaurds , and the rear guards have also been flared to fit rims.
*rims are genuine ssr meshies 15x8 stretch with brand new 195-50-15s fronts and 175-50-15s rear .
*cusco front strut brace.
*ajps adjustable panhard rod.
*sigma LCAS.
*RA40 tie rods with tierod end spacers for extra lock
*aftermarket thermo fan .
*larger twin core radiator
*25mm rca's
all fluids and oils have just been replaced including diff oil , gearbox oil , radiator fluid clutch and brake fluids and engine oil.
this car has no air condition , and all the carpet and sound deadning has been removed to lighten it up even further.car has just been tinted a month ago with 5percent midnight express tints all round.
to see pics of the build please dont hesitate to email me ,i have hundreds of pics or please go to http://www.rollaclub.com/board/index.php?showtopic=35246 for build thread .
located in sydney nsw
https://www.sau.com.au/forums/topic/303178-fat-toyota-sprinter-ae86/
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
