hi everyone , finally up for sale is my project ae86 sprinter.
ive completed everything on this car , has recently had a complete respray in 2pak paint in the famous panda theme which was done in november 2009 .
this car is nice to drive , handles like its on rails and has pull to make you smile .
the body is in good condition , there is absolutly no rust on this car , all rust has been repaired in the process of respraying.
car has no accident damage and is straight .
car is a 1985 toyota sprinter adm
*4age smallport 100kw motor which has been rebuilt 7xxx kms ago with:
*genuine toyota headgasket
*genuine water pump
*all new seals & main rear seal has been replaced
*head studs (genuine) has been done
*cam seals replaced
*genuine waterpump
*timing belt changed in rebuild
*new larger 9 mm leads
*new dizzy and rotor .
its pretty much has all new gaskets through the whole motor
*the clutch is a fresh heavy duty replaced 7xxx ago
*lightened flywheel 4.1kg
*trd extractors with a custom 2.25 inch exhaust , pretty loud .
*t series diff with mini spool
*custom 2liter surge tank setup with bosche turbo external pump , and bosche internal turbo pump
*adjustable fuel pressure reg with gauge
*king springs on the rear , and ajps on the front.
the front guards are aftermarket flared fibreglass gaurds , and the rear guards have also been flared to fit rims.
*rims are genuine ssr meshies 15x8 stretch with brand new 195-50-15s fronts and 175-50-15s rear .
*cusco front strut brace.
*ajps adjustable panhard rod.
*sigma LCAS.
*RA40 tie rods with tierod end spacers for extra lock
*aftermarket thermo fan .
*larger twin core radiator
*25mm rca's
all fluids and oils have just been replaced including diff oil , gearbox oil , radiator fluid clutch and brake fluids and engine oil.
this car has no air condition , and all the carpet and sound deadning has been removed to lighten it up even further.car has just been tinted a month ago with 5percent midnight express tints all round.
to see pics of the build please dont hesitate to email me ,i have hundreds of pics or please go to http://www.rollaclub.com/board/index.php?showtopic=35246 for build thread .
located in sydney nsw
https://www.sau.com.au/forums/topic/303178-fat-toyota-sprinter-ae86/
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
