I have for sale my 1996 r33 gtst skyline located in newcastle for $12 000 ono
Selling due to need a car that is more suitable for work.
It currently has 130 000 km and is regularly services and maintained every 5000km and only good oils used. All other servicing is up to date.
It has minor basic modifications including
FMIC
Electronic Boost controller
Apexi pod air filter
Olins coil overs dampener adjustable only
front and rear strut braces
turbo back exhaust and dump pipe
The vehicle is also fitted with a mongoose M40 alarm system. It has a basic stereo system with a pioneer mp3 head unit with 6 inch jay car speakers in the front doors and and 6*9's in the rear with a alpine v power mono block amp and 12 in sub.
Comes with 6 months rego.
Any more information need don't hesitate to ring me or pm me on 0423144911
https://www.sau.com.au/forums/topic/303272-r33-series-2-for-sale-12000/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
