All Japan Day World Domination Tour 2010
  • Replies 97
Thought i'd take my kids out to see all the cool cars today. Rocked up pretty late and had a quick look around. Only took a few pics as I was worried about the kids touching everyones cars, lol.
DSC_0800.thumb.JPG DSC_0805.thumb.JPG DSC_0807.thumb.JPG DSC_0809.thumb.JPG DSC_0812.thumb.JPG
DSC_0814.thumb.JPG DSC_0815.thumb.JPG DSC_0817_MERGED.thumb.JPG DSC_0820.thumb.JPG DSC_0819.thumb.JPG
DSC_0821.thumb.JPG DSC_0823.thumb.JPG DSC_0831.thumb.JPG DSC_0833.thumb.JPG DSC_0834.thumb.JPG
DSC_0835.thumb.JPG DSC_0839.thumb.JPG DSC_0840.thumb.JPG DSC_0842.thumb.JPG DSC_0844.thumb.JPG
DSC_0845.thumb.JPG DSC_0849.thumb.JPG DSC_0854.thumb.JPG DSC_0870.thumb.JPG DSC_0872.thumb.JPG
I'm available for photoshoots if you want some nice shots of your car. Multiple angles, interior shots, close ups and detail shots. PM me or call for more info.
(yeah yeah, shameless plug. im broke)
Edited by Jay019
man i love that merged pic of marv.... it's freakin awesome!
and it was good to finally be out and catch up we peeps. had a ball, and cant wait for the next one..... congrats to the organisers!
WELL DONE!
Edited by 66 skyline gt
Was an awesome day!
A few mates had their cars in too which was good.
Stand out for me HAD to be the VSpec GTR 34...which was apparently too nice to put on the track, so he bought an EVO for that haha nice work.
Even cars parked on the road to see the event were nice to look at.
Coppers didnt seem to bad too. Apparently some were giving advice on how to have them engineered to ADR Standards, and just telling people what they would be defected for on the roads.
Didn't hear any stoies of defects being handed out or a trap set up nearby...anyone get done?
I've heard that they've issued notices by letter after the even though. Not sure if this is a myth :-S
But seemed like a successful day!
Yeah I spoke to that owner too, what a wanker!
The cruise to the event and back home was nearly as much fun as the event itself! I'll post something more sensible later when I've recovered from my dehydration...
:P Yeah, it was pretty fun :down:
Nightcrawler, are you running full Ti exhausts on the V35 or just Ti tips or just heated Ti look? Either way they look great on the V35
Edited by Weezy
Thanks Weezy - yes as Heslo said they are just heated tips. It was my number 1 'to do' item when I got the car. I was going to buy some Ti tips to put over the stock pipes, but found this axle-back stainless exhaust with them on already, so on it went! I love the look too.
Will tie in well when I put my LMGT4 wheels on (later this week) with titanium burnt nuts - should look sweet.
Then when I buy and put on some Brembo calipers/rotors the look will be pretty much complete.
Titanium burnt nuts? Sounds painful...
:down: I love the avatar
Yeah me too .... wish I had a photo of Glen's face when he realised Domo was gone - THAT would make avatar of the century. Or a photo of his face when he caught me drawing a dick and balls on his Miata headlight would have been classic too. :blink:
Yes, true Kristian - now I think about I shouldn't be so glad about having Titanium burnt nuts :)
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
