Item Summary: R33 gtst skyline silver 250rwkw-11psi- $6k firm
Condition: Used
Reason for Selling: Need money for wedding - So NO SWAPS
Asking Price: 6000
Delivery Methods: PickUp
Contact Info: pm me for my contact info.
Extra Information:
Hi Guys,
Selling the missus' silver R33 Gtst skyline. Have now owned for about 4 years. Got it as a stock standard auto. Professionally converted to manual, so car has a relative easy life.
1995 S1.5 S2 running gear.
Mods;
Bigger turbo - Looks to be a highflow job with t04 internals. Comes on very hard. Alot of potential left.
-FMIC kit 600x300x76
----Custom made split dump pipe by Carline Mufflers
-Stainless steel intake pipe with pod filter (flutters very loud for people who like that stuff)
----Trust 3inch cat back exhaust (quiet as, but when full throttle roars).
-Nismo clutch combo, extremely light weight flywheel and clutch plate itself will need replacing as slips upon boost.
----4.3 diff ratio, lower then normal so it accelerates alot quicker. Combined with the lightweight flywheel this car revs quickly.
-SAFC tuned by HITMAN at race solutions Penrith. Made 235rwkw on about 10-11psi. That was with the auto in it. It's now manual so estimated power would be atleast 250rwkw on the same boost. Never ran more then 12psi.
----Running on stock rims atm, but will through in some WORK VS 2 piece mesh wheels with dish for free...one rim needs repair, tyres are gone.
-Paint is pretty good, a few scratches here and there.
----Car always well maintained using motul synthetic oils.
- Fuel system is stock atm, will need upgraded injectors and pump to push it any further. Potential is there for more power..
Things that need to be done, reason why its cheap.
-Interior needs to be put back together. Had to take dash out and carpet out.
-Needs blue slip. Should pass blue slip fine with stock suspension in which I will give the buyer. The pod is enclosed.
-Needs new clutch plate to drive %100.
That's all I can think of atm..
Price is $6k firm.
Located in Sydney's West.
Pm me for Contact info.
Will get pictures soon..only have one crap one for now
Will be for sale for about 2 weeks, as my wedding is coming up soon and may end up just getting a loan out instead of selling both my skyline's.
Cheers
https://www.sau.com.au/forums/topic/303564-fs-r33-gtst-250rwkw-11psi-silver/
  • 2 months later...
  • 2 months later...
looking to sell this quickly now. $5k...firm..
All its needs is the interior put back in, I have no time or enthusiasm to do it. And then rego and a new clutch.
what suspension is it running? how much rego, pic of other wheels?? had any problems wih it thanks in advance :)
Stock shocks with lowered eibech springs (I think they are eibech). Comes with another set of stock suspension. No rego needs blueslip.
Rims won't come with the car anymore at the revised price, sorry couldn't edit 1st post. I will fix em and put them on my r32.
Never had any problems with the car, bar an alarm burning up. and the clutch is on its last legs. Still drivable but will slip upon boost.
post-28122-1276178112_thumb.jpgpost-28122-1276177805_thumb.jpg[attachment
Will try to get photos of interior..dash/steering wheel/seats need to be put back in. Less then a days work in total.
hey man is car still 4 sale? pm me
  • 1 month later...
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
