For sale: TA45 with TO4 exh housing. (1.15)
Item Condition: Rebuilt by GCG Melb, unused with new wheels.
Price and price conditions: $1200ono
Extra Info: TA45 front with 71mm inducer. TO4 1.15 exh with R trim TA exh wheel. Twin scroll exh housing. Compressor outlet flange needs a v-clamp. Turbo came off a 12at rx7 with best time of 10.21sec. Plain bearing turbo. absolutely perfect for a big hp 13bt!!! Even better for a 20b, low down power!
Pictures:
Contact Details: PM
Delivery & Conditions of Delivery: prefer pickup. COD ok, or other method by arrangement.
For sale: 2x1700 bosch injectors with S4 RX7 secondary rail modified to suit
Item Condition: Used for less than 3000kms
Price and price conditions: $250
Extra Info: comes with S5 primary rail and t piece to run dual fuel lines.
Pictures: post-57469-1263293668_thumb.jpg
Contact Details: PM
Delivery & Conditions of Delivery: Prefer pick up, can arrange drop off.
For sale:APEXi car alarm
Item Condition: unused
Extra Info: Bought by someone else from singapore, I think its still under warranty. Has lots of features. Comes with all wiring and instructions.
Pictures:post-57469-1263293718_thumb.jpgpost-57469-1263293744_thumb.jpgpost-57469-1263293766_thumb.jpg
Contact Details: PM
Didn't know that Apexi makes car alarm. LOL :blink:
Me either, and I tried searching high and low on the net but couldn't find anything. If anyone has any info on it, that's be great.
-Troy
Bump
Pm's replied
Price edit - I will take 1100ono for the turbs and 200 for the alarm.
And if you plan to call and arrange to come around, but don't come and turn your phone off...... don't F#$k'n bother!
  • 4 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
