hi im new to the state and in a little trouble i bought new wheels for my s2 33gtst but i need spacers for the frount wheels as they dont clear the calipers can someone please point me in the right direction on where i can get some spacers in wa????
cheers!
cheers!
try search in WA for sale, try EBAY..
but spacers is illegal mate.. goodluck
I was thinking of getting some also, my front calipers are honestly about 1-2mm away from touching the spokes, should there normally be more clearance? is there anything to worry about? im scared ill take a corner a tad fast one day and shred my precious calipers and rims. have got 225's front and back.
Plus, are there any downsides with wheel spacers, apart from being illegal and "ricey"? - heard stories of driving to work and wheels coming off..
Sorry for all the questions.
You can take a corner as fast as you like, your calipers are never going to touch your wheels.
I was thinking of running some spacers, but decided against it. Why compromise the mechanical intergrity of my car for fashion?
spacers are mechanical? and contribute to the integrity of your whole car now ??
Spacers arent as bad as some talk them up to be.
Slip on spacers are fun for 5-10mm, anything bigger, using bolt on spacers is fine, but if you need that much spacing, you'd be better off buying different wheels.
What I mean is it's another component to fcuk up or fail.
I'm no expert but slip on spaces can't be as 'safe' as having no spacers. You put more shearing loads on your bolts, and because things are never prefectly machined you have scope for 'play' etc and eccentricity, precesion, may lead to vibration and metal fatigue. As for bolt ons now you have more bolts to fcuk up, come loose etc. I just don't trust 'em basically. Don't want a wheel flying off at 100 km around a corner. May be ok for show cars though. :(
Spacers shouldnt be used
full stop
Get wheels that are specified for your car.
You can go on all you want about how they are ok or whatever. Its not going to change my mind on them.
If you use them... you are stupid
full stop
True, they shorten the thread. However, if you get longer threaded bolts put in is that legal. That way your locknuts will fit as they would on a factory spec car. Can you get this certified? Anyone know?
myne were like that for years, were fine until the left wheel bearing started getting some slop in it, spokes started knocking the caliper around right hand corners. didnt do any damage luckily.
auto pro also have slip on spacers
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
