a good upgrade might be a factory GTR clutch and flywheel (from early R32) i have a billet lightweight GTR flywheel and Excedy HD GTR clutch in mine, clutch grip is phenomenal (second gear clutch drop lights all 4s with fat tyres) on RB25DE+T but you pay for it with your left leg, it is brutal heavy and bitey, Ive got a mate with a 4000lB Jim berry full monty clutch, and that's light as a feather compared.
i bought a gtr exedy clutch is thats and good
  • Replies 50
  • 3 weeks later...
how do you know if a GTS4 is a S1 or S2? Also do they use the exact same drivetrain as an r33GTR, gearbox and diff?? Also would an rb25neo mate easily in the r33 chasis.
S1-(1993 - 1995) S2-(1996 - 1998) S2 would have the following : it would have different rear wing different, front ba,r different steering wheel, have passenger airbag, different seats i think its just really obvious.
Chassis number would be ERN33 on a GTS-4, you would see a transfer case in the engine bay to the left of it ( on the drivers side) right down under the engine
all specs can be looked at here
http://en.wikipedia.org/wiki/ATTESA (look for ATTESA E-TS system)
ATTESA E-TS system is used in the following models:
* R32 and R33 (1989-1997) GTS4 Skyline
* GT-R - 1989–2003
* Nissan Stagea
* A31 Cefiro
* Infiniti G35x/Nissan Skyline (V35 & V36)
* Infiniti M
* Infiniti FX
* Infiniti EX35 (with Active Brake Limited Split for side-to-side torque split, as needed)
* Nissan Fuga (Known as Infiniti M in export markets)
Edited by niiko101
how come my cluster and another r33 cluster is different the other one has slip light and A-LSD light in the middle of the rev counter and mine doesn't could this be due to cluster change or mine just doesn't come with it.
Edited by niiko101
You must have had your dash replaced, maybe with a lower k one?
Mine has a Slip light and a 4WD light. They both come on with ignition but I've never had the 4WD light up, only the slip.
if i got a proper gts-4 cluster how would i go about wiring up the slip and awd lights?
Edited by niiko101
the plugs on the back of the dash should both be the same so it should just be a case of unplug 1 dash and plug in the other. doubt there will be any need to touch any wiring as it should just be 1 or 2 big plugs (can't remember if it's 1 oe 2 plugs)
The first picture is of an automatic gts-4, dont ask me why but the automatic gts-4 has a A-LSD light (As you can see in an owners manual for r33's) where as the manual skyline has a 4WD light instead of a A-LSD light, they are the same thing and they still have a A-LSD in the rear wherther it be auto or manual transmition......
Also that picture says the orange warning light is transmition well thats bullshit because its a engine warning light so dont believe that,
R33 GTS4 CLUSTER SERIES 1 AND 1.5
(right side of cluster) The 2 ontop you should have a seat belt reminder light (i dont think this works with compliance seatbelts), engine warning light,
Then the 3 below are, oil pressure warning light, exhuast warning light and battery warning light.
(left side of cluster) The 2 ontop are, door ajar, SRS air bag warning light
Then the 3 below are Low fuel warning light, ABS warning light, Brake warning light (used for handbrake but also reads when your low and brake fluid)
Then you should have 5 gauges, following from left - right
Water tempature, Fuel , Speedometer, Tachometer, Oil pressure
So far thats a GTS cluster, the last two things are a GTS4 thing and its SLIP and 4WD inbetween the Tachometer
Judging the second picture is yours, the cluster is a GTS one. It will work fine in a GTS-4 because its got a few pins missing that the GTS-4 cluster uses for the SLIP and 4WD lights. There for the 3 plugs on the back plug in as normal but the extra pins on the plugs for the GTS-4 for your SLIP and 4WD lights have nothing too do.
Has anyone ever seen there SRS, Fuel or seat belt lights in the working? i cant get any of them up when i have igntion on and am suspection the seat belt one wont work......but fuel never comes on when im low and just have never seen the SRS one and im not game too make that one show :D
thanks for that, lol nah i have never seen the fuel or srs one come on ither, my seat belt one works tho
Edited by niiko101
different car i know, but my SRS light comes on in my pulsar everytime i start the car. can't remember if it did in my 33 or not, been too long since i owned it
only does it for me on start up
Edited by niiko101
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
