Hi folks, have had this turbo sitting around for about 6 months as i was planning on getting a new centre ball bearing, water cooled cartridge for it from a turbo rebuilder in Sydney. The aim was to see if there really is any difference between plain bearing and ball bearing.
But, interest and funds and other things in life are such that when my POS gets back on the road i couldnt be bothered with this sort of trial and error at my own expense anymore. SO up for sale is my spare TD06L2-20G. It runs an 8cm housing. It is used but wheels are fine and no abnormal shaft movement or play.
A word of warning, i bought this off yahoo auctions where it was a sold as a used runner, but being used and something i have not trialled myself, be prepared to perhaps get it rebuilt ($400-500) I dont expect this to be the case, but i cant personally vouch for something i have not run.
Asking $1350. If you are interested in a bolt on setup can do it with my used Greddy manifold and gate, with some cooler pipes and lines for $2500
https://www.sau.com.au/forums/topic/303846-trust-td06l2-208-with-8cm-housing/
  • 6 months later...
The manifold and gate, dump pipe, oil supply and return are finally off the car so is now a complete kit. Previous buyer seems to have lost patience with me (completely understandable considering how long it tool to get off my car) so now taking new offers
So asking $2k for the following:
- TD06SL2-20G with 8 cm housing pictured above
- Used Greddy RB20/25 SS tubular manifold
- Used Greddy Type R Wastgeate with 8psi spring
- Supply oil line and return line. Both braided PTFE with the return line covered in high temp silicon sheathing ($80 alone for sheathing)
- Turbo to cat "3 Dump Pipe (mild steel) May or may not still be fibreglass wrapped
- 3" Straight thru pipe in 3" cat (track only)
- Turbo to inner guard cooler pipe
Ideally looking for pick up from Bayswater...most the parts you need for a bolt on kit, will just need to play with your Filter to turbo piping and maybe modify your turbo to cooler pipe.
If anyone wants everything minus the manifold so that they can use an ebay, 6boost, ETM manifold on their RB/SR etc then wipe of $500 from my asking price, thogh not sure what good the dump pipe will be to you ... ideally this will go to an RB25 or RB20 owner.
  • 4 weeks later...
OK, am now back in Australia and as per above have :
Need it gone and only asking 2k if you are in Melb. If you require delivery interstate then may be able to help out with delivery
The 2k asking price is for only those in Melb who can save me the pain (and themselves) of packing all this stuff up and the cost of posting.
Below are some pictures i took yesterday
A close of of the two minor repairs i have done to the manifold over the years...
Dump and "Stuff" that the kit comes with...
Those PMing me with where it comes on boost etc. Forgetting dyno sheets it hits and pulls hard from 4,500rpm....it hits 19 or so psi several hundred rpm before that, but its not until about 4,500rpm when the engine gets into its stride,
Some videos to give you an idea of the performance at the track at noise and also on a skidpan where you can where it alls off boost / comes on to boost etc
Track Work
Skidpan
Edited by Roy
Bump, was holding the kit for a guy and had a second party waiting on his decision...seems I shot myself in the foot with 2 weeks passing and both parties now walking away from the table. So this time round, no holding for people or stalling other interested parties because we are chatting via PM. First person fronting the money will get the kit
No longer for sale. The setup now has a happy new home...the one make series is growing and now has 3 x TD06 powered R32 GTSts ! :P
Still have the near new Greddy type R gate that was going to be used with the 25G... $500 woudl be nice but will take 450 and its yours :)http://www.skylinesaustralia.com/forums/Td...html&hl=25G
Edited by Roy
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
