  • Replies 54
Dont help this year, but we will be looking at these sorts of events next year... However the k's / $ and relative to distanc hauled is always a consideration. These events are critical, because they are ideal tests for the bigger shows.
Rally Tas struggles... and that is one of the best value for money events in the country. Plus it uses some Targa stages. Why more people dont use it as Targa Test I dont know... yet Targa West Point is fully subscribed. Biggest problem is AASA v CAMS rules me thinks.
TT
TT
You would likely be more in the know than I, but ive heard that due to low numbers its likely Rally Tas will go gravel and be based on the original Southern Safari ARC event (as an ARC event)? Would be a shame, I reckon Rally Tas is a great event, great roads and burnie is a great place to hold it.
What you mean more in the know... You Nav broad minded persons get all the good gos! I feel a bit sorry for MSR as they bought a brand that was on the way down and couldnt turn it around. There is a big conflict when you are trying to run a round of the ARC in Tassie and keep it on Tamac.
I think CAMS needed to tow the Octagon line and not let ego's get in the way... Then we would have one set of rules, and in a shrinking market the best rallies on Tarmac would be supported.
We are just doing a tear down for rebuild... and either build a AASA weapon (CAMS cheater) or CAMS compliant (AASA non competitive) thiing.
Personally I think they both have it wrong, and somewhere in the middle would be good.
Anyhow I digress... The big W is off the gaspers!!!
And I cant wait to do some of these types of events (inc road trip for the crew). Can do 3x per year for the price of Tugga.
in a shrinking ecconomy and budget pull back... I think that is the way to go.
TT
Love the way the Auto Mod changed 5Lut5 to "Broad minded Persons LOL
Edited by Targa Tom
She'll be fine Timmy no panic. Just bring ya mouth guard.
Just needs tyres, brakes, fliuds, stickers, and other assorted annoyances.
Just drop it round to RGM Racing and tell em see ya with it in Townsville! Im sure thats what Russ does!
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
