Hey Guys,
I have a fuel rail kit to sell it is a complete kit minus injectors but if you would like I can include a set of 575cc or 750cc or 870cc Siemens injectors for an extra $550
The kit includes:
Custom Billet Fuel Rail to suit RB20DET or R32 RB25DE (Common RB30DET Head conversion)
Suits 13mm O Ring injectors - this is still at the machine shop but should be ready to pick up this week
From what i have found you wont get one of these anywhere else as I couldnt get one anywhere and had to have this custom made for my setup
10' of -6 Braided Line
Mixture of earls / Speedflow -6 fittings in blue red
3 x 90' Bend
3 x 45' Bend
2 x Straight
3 x -6 to 3/4' NPT
1 x -6 to -6 NPT
1 x -6 T Block
Turbosmart FPR1200 (Near New - just run on dyno) with bracket
Turbosmart Fuel Pressure Guage
$1100
Had some interest minus the RB20 Fuel rail
I will sell kit as a package without the rail for $750 you could them match it up with one of these awesome RB26 Hypertune Fuel rails for $380 here: http://www.skylinesaustralia.com/forums/Hy...92#entry5034792
Everything is Blue/Silver/Red and will looks stunning in your engine bay I really want to install it but I dont really need it any more as its kinds overkill for my setup and i have bills to pay :P
Edited by dano4127
  • 3 weeks later...
  • 3 months later...
still got this kit - even better deal now that the ass has dropped out of the aussie dollar and prices have all risen...
Make me an offer...
  • 2 months later...
3 x 90' Bend
3 x 45' Bend
2 x Straight
3 x -6 to 3/4' NPT
1 x -6 to -6 NPT
1 x -6 T Block
Turbosmart FPR1200 with bracket
Turbosmart Fuel Pressure Gauge
Paid $700+ selling for $500 Firm
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
