  • Replies 51
RB30DET.
Where the engine rebuilder is getting the pistons, they open up apparently this week, so its soon. ;)
If you don't go forged pistons in the RB30E short motor and use the standard NA pistons you will have a 8-8.3:1 CR, which is good for turbo. Without forged pistons you will be stuck reliably at 250rwkw with a good tune. If you start heading towards 300rwkw the cast pistons wont handle the heat and break.
I used a R32 GTS RB25DE head (Like yours) had it rebuilt, ported/polished & inlet valves deshrouded. The cam specs for the head are 240dur 7.8mm lift on the inlet and 232dur 7.3mm lift on the exhaust. I'm going to use the 240dur 7.8mm exhaust cam from my RB20DET to help open up the top end a bit more. If it makes power to 6000-6500rpm then starts to drop off I'll leave the cams standard. If it drops off before 6000rpm then I'll throw a set of 256dur 9mm lift cams in it.
Do your figures. Work out how much its going to cost to get an RB25DET & RB20DET in the car with a working ecu (RB25DET = wiring mods, RB20DET will work easily with a T ECU), then work out what it will cost to give a RB30E short motor a freshen up (~1-1.2k) buy a head gasket, bolt on your RB25DE head, pop down to a jap importer & grab your self a cheap highflowed turbo, buy an second hand exhaust (~$700) then get your ecu remaped and have a solid easy 200rwkw with no lag and quick acceleration as you idle off from a set of lights. :P
It stresses me having to play with the clutch then waiting for the turbo in first to try and take off a little quicker than normal.
..Do your figures. Work out how much its going to cost to get an RB25DET & RB20DET in the car with a working ecu (RB25DET = wiring mods, RB20DET will work easily with a T ECU), then work out what it will cost to give a RB30E short motor a freshen up (~1-1.2k) buy a head gasket, bolt on your RB25DE head, pop down to a jap importer & grab your self a cheap highflowed turbo, buy an second hand exhaust (~$700) then get your ecu remaped and have a solid easy 200rwkw with no lag and quick acceleration as you idle off from a set of lights. :P
I should proibably point out that i only have an RB20DE atm, meaning to go to RB30-type stuff, i would need another head (RB25DE) as well as block, turbo, ecu, wiring, Dump pipes, Intercooler etc, etc. as you've already suggested. some things i was wondering about though are the RB25DET you said would require a wiring change - aren't the sensors and stuff the same? it would definitely need another ECU to handle the increased airflow, different capacity etc, but shouldn't it just plug straight into the existing harness? As for the RB20DE, would that even make a worthwhile difference ? or would it be bettter to just hold off and go all out with the RB30 idea? <- this last ones open for comment, btw.
phil
Joel,
You forgot to mention new injectors and fuel pump also, as the GTS Gear won't cope.
Trust me I added up the cost both ways for my conversion, and the RB25DET works out a lot cheaper, every time!
It's costing me:
$2100 for a 1995 RB25DET (64,000 km) engine, ecu, intercooler, wiring loom and fuel pump
$600 for a CES twin dump/front pipe (though you could get a cheaper single dump for $250)
$315 GReddy Turbo timer and Apexi pod filter
$800 labour to swap it all over
And after it's complete I can sell my RB25DE engine, ECU, and wiring - to recoupe some of the costs.
Sure a RB30DET would be nice, but when I added it all up (doing it properly and not dodgy) it was going to cost in the region of $8000 - (RB30 bottom end with forged pistons and balanced internals, turbo + manifold, dump/front pipe, intercooler + piping, blowoff valve, fuel pump, aftermarket computer to run the larger injectors). And with the RB30DET putting out so much torque, it would surely destroy my clutch and gearbox.
I am envious though Joel, if I could justify throwing the money at a RB30 conversion, I would have. But at the end of the day the RB25DET made far more sense.
Ryno
It is a bit of a bummer if you don't have turbo to start off with.
I'd just bolt up the turbo bits to the NA with its decent compression ratio it should go well, better than a similiar modded T.
I think go to pieces might be more accurate... :P the high compression ratio would put way to much strain on the internals, or so im told. I think there were some posts earlier on in this thread about the addition of a turbo to a N/A engine... ill have to check though...
All comes down to how much power do you want to make. Be it now or later down the track.
Its a bit of a waste of money to buy a RB25DET if you are only going to rebuild it with stronger internals, different turbo,injectors, I think this is where the RB30DET begins to become better value for money.
It can also depends how much your willing to pay extra to have a freshly rebuilt engine.
Work out the $$, the pros & cons then make a decision.
I've always liked cubes. :D
Comparing the RB25 to the RB20, 500cc's makes a hell of a difference.
While your spooling i'll be short shifting down the road. :)
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
