NISPARES have the GTS2 side skirts, front bar and the GTS2 spoiler. But there expensive.
R31 GTS2 FRONT BAR/SPOILER $770
GRILLE $220
GTS2 SIDE SKIRTS $385 PAIR
GTS2 REAR SPOILER
NON-STOP LIGHT TYPE$350
REAR BAR 3 PIECE $880
You could also buy just the Front spoiler ( grey Extension on the bumper bar in my sig ) and side skirts instead of the full front
But it depends on what series R31 you have, the Ser3 wont fit ser1 & 2.
https://www.sau.com.au/forums/topic/30471-r31-bodykits/#findComment-617641
Your profile says you have an 87 Skyline.......
Take into account that unless you have converted the front to series 3, that the GTS2 bits won't fit on the front.
and if you wanted to change the front bar, you'd probably aslo need to change the reo.
https://www.sau.com.au/forums/topic/30471-r31-bodykits/#findComment-617965
sky031- i posted in the r31 club (rsxrb20det) about a pintara TRX that i saw here on the coast as i was very interested in the body kit for that, its sweet, also on REZZs' k's garage site there are some great updates, would love the r31 bonate (car'nt spell for shit), but over a grand then shipping is a little out of my budget for now!!
https://www.sau.com.au/forums/topic/30471-r31-bodykits/#findComment-617980
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
