UP FOR SALE:
2 x Focal 165A1 Components (2x tweeters, 2x 6.5" midrange, 2xCrossovers) - $350
1 x Clarion Pro Audio Boxed Subwoofer - $150
1 x TARGA Amplifier (American Made, 4 channel, loads and loads of power (i'll try find the specs, easily ran all of the above system without issue) - $250
1 x Capacitor (2 Farad) - $100
System was used for 6 months, then I sold the car and I have no use for it now. Everything is in immac condition, I can upload pics if you really want.
OR
Buy it ALL for $800 and I'll throw in all the speaker cables, RCAs that you need to wire it up. That's basically a top of the range complete system for $800!
Located in Melbourne (SE)
PM or call 0423280746
https://www.sau.com.au/forums/topic/305222-complete-sound-system-for-sale/
  • 4 months later...
