Hey, I have a S2 Stagea on the way and in the shed I have a Garrett gt3076 and a stainless manifold.
What I would like to know is what mods will be needed to run this on my car? The Stagea is dead stock atm so I was planing on a FMIC and decent exhaust first off.
I also have a Blitz DSBC and a Z32 afm for it too.
Im not after massive power figures either, just something thats gonna be fairly shocking to Commodore drivers!
Thanks in advance for any help or advice anyone can offer me.
Chris.
https://www.sau.com.au/forums/topic/305254-rb25-neo-garrett-gt3076-questions/
lol... Yep... So many threads about this. Basically the same as everyone else.
AFM
Injectors
ECU/Tune
New manifold, more spacer plated stock one - i bet the one you have is a ebay special, so forget that.
FMIC
Exhaust
Around $6,000 basically.
I would also imagine you are Auto, and that will need some attention - add another $1200.
Cheers, the manifold I have is SN Power or ZN Power or something like that, wasnt from ebay.
Yeah its auto too, I was thinking maybe a stall con + shift kit or something.
Also are the C34 ecu-s re-mappable?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
