Performance Parts Clearance Hks T51r Turbo Kit, Trust Sump, Arp Head Studs, Mahle Pistons, Sard Injectors, Hks & Os Giken Cam Gears!
Hi Guys,
Sadly my car will never come to fruition so im clearing out the garage
Used Performance Parts
HKS T51r-KAI Turbo Kit to suit RB26 (800ps version)
HKS exhaust Top mount manifold
HKS GT Wastegate
HKS steel exhaust gaskets
Greddy dual Intake Pipe
Custom dump/front pipe
4,000kms old, no shaft play what so ever, Inspections welcome
$3500
RB26 Ross Balancer $450
Tomei Cam Gears $200
Sard 720cc injectors with Greddy Fuel rail $915 FIRM (not seperating)
RB26 Sump with TRUST Sump extentsion welded $800
(Includes R34 GTR diff)
Venolia Pistons RB25 Good condition (needs new rings) $400
6x Stock Rb26 rods $150
GTR stock turbos $200 turbos (no manifolds)
Brand NEW
ARP Head stud kit to suit RB26 $350
Mahle 26/30 Pistons 86.5mm pistons/rings/pins $720
Gives a 8.5 Comp ratio
N1 Oil pump $400
only opened the box to look at it, never installed
HKS Timing Belt to suit RB engines $100
Genuine RB26 Nissan Gasket Kit (the one with a billion pieces) $300
1000cc Injectors Rochestor Brand comes with 14mm Top feed fuel rail $500
HKS Cam gears (New design pink duriluim, not the old ones) $350
OS Giken Cam gears $300
3x Genuine Bosch 044 Fuel pump $200each
100mm FMIC to suit GTR $300
R33 GTST stock parts
2x Dump pipe $10 each
Front pipe $10
2x Exhaust manifold $40 each
Intake manifold (corrosion on radiator hose pipe) $10
Damaged Thermo Free
Power Steering bottle $10
SMIC with piping $40
Washer bottle $10
Radiator overflow bottle $10
R33 front pair of suspension (pit use) $20
Pair of indicator lights (clear) $20
R33 cat back exhaust (tiny hole in muffler and surface rust) $50
TurboSmart BOV Type 2 $80
Tcc Tech BOV Type 3 $50
R32 GTR boost solenoid $50
6x Stock rb25 rods $100
RB30 head (SOHC) comes with intake and exhaust manifolds $100
PM me with any questions
Located in PERTH but can arrange postage
Edited by R32 Driver
  • Replies 42
Posted Images
Hey,
Sorry to be a pain, but do you have any pics of the individual pieces of the turbo kit? I'm thinking of going big-single.
Thanks!
Hey,
Thanks!
Ill take photos of the kit tomorrow morning, however i wont be seperating the kit :)
Thanks for posting pics. Do you know what width the dump/front pipes are? What kind of use did the turbo see in those 4000km's?
Cheers!
3.5" dump and its a dump/front pipe in 1, made out of mild steel
Unsure what the turbo saw during the 4,000kms but Its been checked by a professional workshop b4 purchasing and no shaft play at all (Inspections welcome)
Tomei Cam Gears SOLD
N1 Oil pump SOLD
HKS Timing Belt SOLD
3x 044s SOLD
1000cc Injector and rail SOLD
ARP Headstuds on HOLD
Steve
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
