1998 R34 4 door sedan
RB25DET NEO engine
167,xxx kms
Tiptronic trans
3" turbo back exhaust with HKS muffler
Greddy FMIC kit
Apexi POD filter
Turbosmart bleed valve set at 10psi
Pedders lowered springs
Traction control
Climate control
ABS
VLSD
Air bags
HICAS
Nissan flooormats
Kenwood DVD/MP3/DIVX player connected to nissan satnav screen (screen not currently working due to a dodgy wire)
Viper 5900 pager alarm/immobiliser system with remote start and turbo timer
Rear wing professionally removed
3 months rego
$12500 ono with the 17 x 9 Volks or 17 x 8 and 16 x 8 Enkies (see my other thread for pics)
$13000 ono with the 17 x 9 and 17 x 8 Advan wheels (see pics)
$14000 ono with the R34 GTR 18 x 9s with near new tyres (currently fitted)
PM / post here or call / sms me on 0410340449.
https://www.sau.com.au/forums/topic/307180-nissan-skyline-r34-4-door-sa/
BUMP for the R34 4 door :blink:
Price also includes a set of Aragosta fully adjustable coilovers, a pair of new adjustable rear camber arms, full standard exhaust and a heap of other spares...
PRICE DROP
$12000 with the 17 x 9 and 17 x 8 Advan wheels or $13500 with the R34 GTR 18 x 9s with near new tyres.
I will sell the wheels seperately or swap/trade for Work Emotion XT7s in 17 x 9 +17.
  • 3 weeks later...
  • 4 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
