Just wana help any of you guys out there who are looking for an GTR... I know a few R33 GTR for sale. The car does not belong to me but it also does not belong to my friends, I just came accross those cat while i am looking for an GTR for myself...
Here is the list of car which i have found.
1. 97 GTR with Ode 45K selling for $35000(on the road) but the clutch and radiator seen to have a problem. This car is complete stock.
2. 95 R33 GTR with around 60 to 80K on clock .. selling only 32K (does not included on road cost) but it seen to be accident. This car look great and have a few mod on it.
3. 95 R33 GTR with around 60 to 80K on clock selling for 35K. The best car in my list.. have a few mod on it too,,, I get this car for myself if i am serious after an GTR now.
The 97 GTR should be gone soon because of the price.
PLS i dont have any PIC nor I am not intent to help you to get it, I am just here to HELP you guys out. PLS call me if you me or msg me if you have the money on you hand ,,, pls dont wast my time if you dont have the money. Again those car does not belong to me or my friend, It just happen to fall in my list of searching car...Call 0418 388 125
Thanks
Calvin
https://www.sau.com.au/forums/topic/30722-r33-gtr-35k-only/
you dont have to give the money to me ,,, pls dont get me wrong.... i am here to help you to buy it.. the money does not enter my hand but then again afcouse there is some condition appy.. Those people has put a higher price on trading but they have gave another set of price,,,, hope this explain..
Reason why i dont buy it,,, well if you can get a Good condition GTR for just 30K in next 3 or 4 month time.. what will you do .. for me i am a student 5K is alot for me. SO i intend to save the money...
https://www.sau.com.au/forums/topic/30722-r33-gtr-35k-only/#findComment-621829
GUYS pls call me if you are interested... no SMS me pls... show me some interest... if you are going to buy a 30K car ... i am sure u can spend $2 for a phone call. If you are try to save the phone call $$$ then get a hyundai excel....
https://www.sau.com.au/forums/topic/30722-r33-gtr-35k-only/#findComment-628682
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
