Up for sale are my 550cc Denso injectors (skinny pink style), they are top feed high impedence to suit RB20 setup (will fit GTR just need to remove the resistor pack).
Bought them new from Powerflow Injection, they've done ~5,000km in my RB30DET, small turbo so were never pushed hard. Have upgraded to 1000cc injectors to go with the new turbo setup so the 550's are no longer needed.
Items located in WA and come with matching plugs.
Price: $700 including shipping.
