Selling my 1986 RX7 FC
- Price: $14,000
- Contact: 0406737880
Full Rebuild With Race Spec Engine (1500km's)
Includes:
* Full Mazda seal kit
* Ported and Polished
* New Apex seals
* Corner seals
* Full engine re-spring
* Side seals
* Oil control rings
* New rotor bearings
* New stationary gear bearings
* Water seals
* Side plate re-surfaced
* Full race clearancing
* Modified oil galleries
* 8 additional dowells
* Turbo extend porting - Inlet and exhaust
- Large Extend Ported
- Garrett GT35/40
- Trust SSS Manifold
- 45mm Turbosmart Wastegate
- 900cc Primary Injectors
- 1700cc Bosch Secondaries
- Bosch 040 Fuel Pump
- PWR Intercooler
- Microtech LT10's
- Bosch Coils
- New Bushes
- Brand New Tein Super Street Coilovers (0km's)
- Extreme 1.5 Tonne Pressure Plate & Custom Single Plate Clutch
There has been alot of money and time spent on the car from Maztech and Rotorworx.
Maztech tuned it to 12 psi which pulled over 300hp at the rears
After the engine running in should expect over 400hp at the rears on 18 psi.
The car has reg till april 2010.
Edited by gtrkid123
https://www.sau.com.au/forums/topic/307367-rx7-fc/
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
